My battery maintainer and Marinco plug mod.
I bought a CTEK 3300 battery maintainer and wanted it permanently attached to the truck. I also wanted to do the Marinco plug mod but didnt want to cut the cord off the maintainer to hook it up so I wired up a short cord off the back of the Marinco plug with a female plug on the backside so it can be unplugged anytime.
I decided to put it just under the passenger side headlight on my ranch hand.
Here is the plug with the cord wired on.
I ran the plug up beside the headlight and the space behind the grillle and ziptied the excess wires away.
Mounted the maintainer on the cover on top of the radiator.
Yeah, I have a fairly similar Ranch-hand on mine, and I can't imagine drilling a hole in it. Your's looks really good.
Thanks. I was debating on not putting it there but it blends well, one things for sure it sure is tough metal. My truck had the ranchhand on it when I bought it. Yours looks like it sticks out a few inches from the truck like mine does. Ive got room I can stand between mine and the grill if I have my feet turned sideways. Ive seen some that are so close to the grill that you couldnt slide a sheet of paper between it.
The maintainer came with both alligator clips and eyelet ends incase you want to permanently attach to the battery. Got the positive cable hooked up and the ground going to the alternator bracket. It has a quick disconnect on the cable in case you want to move the maintainer to another vehicle.
Mounted one of these to my barn in CO for working inside rather than
having to run extension cords all the time.
ReelWorks Retractable Cord Reel 40Ft., 12/3 SJT Cord | Cord Reels| Northern Tool + Equipment
"When" I move there I'll do something like what you did to plug-in.
In FL, not really an issue..
FUJINAMI1293
03-18-2013 10:16 AM
Swimholm
01-08-2012 11:01 PM
