help!!!!
Old 02-19-2013, 11:11 AM
raptor131's Avatar
raptor131
raptor131 is offline
Originally Posted by budlightman11j
i also wanted your guys opinion he gave me the option to do an egr delete kit is that worth doing and getting rid of the cooler? i live in florida and we dont have emissions down here!!! or shoul i keep it all OEM?
Can't fail if it ain't there. But tell him to keep the egr valve and keep it plugged in to keep everything happy
Old 02-21-2013, 08:35 AM
budlightman11j's Avatar
budlightman11j
budlightman11j is offline
well egr is definitely blown and he said i need an oil sender not sure what its for but i need one and i need a new turbo hose!!! egr delete is in and new oil cooler is order and he should start putting everything together tonight!!! is there anything i should replace while he has everything apart?
Old 02-21-2013, 10:01 AM
mustang_309's Avatar
mustang_309
mustang_309 is offline
If you haven't done so already the blue spring upgrade for the fuel pressure regulator is a good idea.
Old 02-21-2013, 10:32 AM
budlightman11j
i have already done that upgrade that was easy lol!!!
Old 02-21-2013, 06:24 PM
jedlicka87's Avatar
jedlicka87
jedlicka87 is offline
A updated STC fiting with new HPOP o-rings wouldnt be a bad idea.
Old 03-04-2013, 08:17 AM
budlightman11j
all done
well egr cooler was deff gone!!! did the egr delete kit with a new oil cooler!! i have been having a problem with the no power in the morning turned out number 2,4 injectors where on there way out and number 6 was shot!! so i replaced 2,4,6,and 8 injectors!! my oil sender was leaking and needed a new one and connector and the blue house next to the turbo was split so i replaced that!! after all that i am pretty happy the way she runs now cost me after labor and parts @2750.00!!!
Old 03-04-2013, 08:26 AM
BLADE35's Avatar
BLADE35
BLADE35 is online now
hope they flushed the cooling system
if not a flush might be in order here
also a coolant filter is a good idea if you dont have one yet
Old 03-04-2013, 08:30 AM
budlightman11j
he said he did do a coolent flush!!!
Old 03-04-2013, 09:53 AM
BLADE35's Avatar
BLADE35
Well thats Great
However some of these trucks take Many Many repeated flushes to clear the system out Something Most shops Fail to do
Some of us me included went to GREAT LENGTHS to Inshure a Clean cooling system
Running Cleaners pullen thermostats undoing all cooling system connections and stuffing the hose in to flush Pullen block drain plugs with many many cycles as there are Lots of places for Casting sand to Hide in there
Im not saying the Guy screwed up but I doubt he went that far with it
The guys that dont flush good usually have the same issue 10-15K down the road just enough time to Kinda put it behind them and forget some shops reliey on this for Job security
I bet I had 10hours into Flushing my coolant system out over 2 days with 3 diffrent cycles of VC-9 Cleaner. I even opened all block drains and just let the hose run threw it for awhile if you remove the thermostat and stick hose there thats considered a reverse flush of the Block.. I did a Bunch of Flushing one day added a Coolant filter drove like this for a Month then Did another round of flushing only the second goaround I replaced the Oil Cooler. SO far it looks like it paid off as my ECT and EOT spread is only 2-6* this time of year and stays about the same driving around town
If I was in your shoes Id add a coolant filter for shure
mcompton1973
02-05-2018 08:13 PM
cookingguy
11-15-2014 05:50 PM
steelkiwi75
11-10-2013 11:32 AM
schusker
07-10-2011 08:03 PM
DW3555
1999 to 2016 Super Duty
20
07-20-2009 06:43 PM
Quick Reply: help!!!!
