help!!!!
help!!!!
first off i a have a 2004 f250 with 194,000 miles on it just did and oilchange less then 500 miles ago plus fuel filters!!! i just got back from a trip on sunday and when i got in my truck monday everything was fine dropped the kiddos off at school and when i got back to my truck and started it up a huge pile of white smoke came pooring out of the tail pile and then went away!! well i went to go to work this morning and tried to start my truck this morning it wouldnt even crank over like the motor is locked up!!! i did pop the hood and notice all my coolent is gone!!! i am ready to light this thing on fire lol!!! any suggestion on what i can do or is this a loss cause? thanks guys!!!
Gonna have to pull the glow plugs to get the coolant out of the hydrolocked cylinder(s) and then hope its just a bad EGR cooler. If you do the EGR cooler do the oil cooler as well as that is what caused the EGR cooler to fail. Unfortunately the only other possibility is a blown head gasket.
Possible egr cooler rupture also, since it sits over the passenger side of the motor and plumbed into the passenger side uppipe, any rupture here and the coolant leaks down inside the exhaust side of the cooler down the passenger side manifold and into your exhaust
Valves and into the cylinder, causing your hydrolock.
Of course this is a guess, but pull the egr valve and see if it looks wet in there, then, if it does, pull the passenger side glow plugs, pull ficm relay and crank it till she chooches all the coolant out.
the degas bottle is empty and i dont see and leaks anywhere!!! i checked the oil and there is no water in it!!! thank god!!! i had a buddy give me a quote to do everything for about 1200.00 bucks is this a good deal?
I'm assuming this is to repair the egr cooler? If so, it is not a bad price. If you repaired it yourself, the cooler is only $350 for a bullet proof one. I would do it myself, 1200 is a lot of money, but repairing the egr cooler should go ahead and do oil cooler too while it is apart
For the average joe it takes all weekend to do this job, took me 4 days and I was taking my time, it is a lot of work, and the turbo uppipes are a PITA to line back up, I would not Do this work for less than that
