Numerous 460 big block engine parts and E4OD Transmission for sale
#61
Category: Accessories
Price: $1
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): Fit, S2000, Motorcycles, Hybrids
Item Condition: IA
Shipping Information: Item can be shipped
Engine: Part suitable for gas truck
#63
Updated the list.
Two radiator fans/clutches from both a 1986 and 1996 engine, Make Offer
1996 Piston and connecting rods with bolts, 7 available, make offer on 1 or more.
1996 and 1986 exhaust manifold sets, make offer.
Plastic radiator fan shroud from the 1996
F3TE heads, 1996, asking $125 each or $200 for both.
1996 valve covers, center bolt, cast aluminum, OEM, make offer.
1986 valve covers, edge bolt, OEM, make offer.
Breather tubes, airbox to intake for 1996, make offer.
Holley OEM carb that came off of the 1986, taken apart, most parts are still with it, make offer.
Oil pickup tube/screen and oil pump if you want it, make offer.
Full set OEM lifters and push rods for them, make offer for 1 or more.
Aluminium AC/Power Steering/Alternator brackets with some of the bolts from the 1996, make offer.
Crankshaft belt pulley from the 1996, make offer
Re-manufactured alternator from the 1996, make offer.
Due to my job my responses to PM's might be a little slow. I will list more as I sort through the mess in my garage.[/QUOTE]
#64
Updated the list.
1996 coil and mounting bracket with various emissions clutter, make offer.
I thought the 1996 coil etc. was in one of my boxes?
#66
Just added:
1986 E6TE(?) 460 heads. I couldn't find any casting numbers but found a date code of 5K17 which puts them in the area of 10/1985 from what I found. One has exhaust manifold 2 bolts broken off and the other has a hole that might need a tap chased down it but otherwise looks good. Spark plugs not included. $125 each or $200 for both
1986 exhaust manifolds off of the same heads. One side had the emissions ports cut and pinched and the other side has the ports plugged with bolts. No cracks or damage otherwise. I cut the exhaust pipes before the clamp and will leave them that way. $30 each or $50 for the pair.
Shipping is not included in the prices.
#69
Sounds good, Your PM's are disabled so you can email you shipping address me at my forum user name with a @gmail.com at the end of it. I will reply with payment options.
#70
Thanks. Email sent.
#71
Shipped today via USPS Priority.
I found that out while looking for casting numbers for the heads. Summit Racing has the OEM copies for the exhaust manifolds for over $220 per side.
RabidJade
Ford Truck Parts for Sale
11-11-2013 09:21 AM
b37mech
09-30-2011 04:30 PM
460jet
12-30-2003 06:04 AM
