Who makes the Best EGR Delete Kit?
Cheezit Knows Best here
But the Way I figured mine was I ran with the EGR Valve UNPLUGGED for awhile I never got a Light Nothing so I deleated it and still nothing
If you do Get a CEL from being unplugged Post the DTC
Ultimatly in the End you will Deleate the EGR Cooler but you will Leave the EGR Valve Installed in the truck and it will also be plugged in this will Keep the PCM Somewhat Happey
On the stock EGR cooler I just brazed a freeze plug into the inlet side and then put a piece of flat ss on the outlet side along with some high temp silicone just in case it sprung a leak. Left everything else in there. Computer still actuates the EGR valve but no exhaust gases are actually being routed. Works fine.
Josh
I wouldnt tell you to do something like this if it was High Risk
Yes Sir Fan issues with the EGR Valve unplugged But he wont have any problems for a Few days just to test Plus its winter
But Guess I should have been More Clear
Its winter Now you wont really need the fan unless you tow or something
But Nothing will Happen if you unplug it for a Day or two just to see if the trucks going to throw a DTC with the EGR Unplugged
It would be best to go 3 days or a week even better But you need to compleate a Minimum of 3 Drive cycles
I ran my 03 this way for a Year the only affect I had was Intermediate Fan steps didnt kick in but when ECT hit 221* it did Kick fan in High and cooled things down Fast it was Also July and 100*+ ambeint temp
Just use your Gauges to keep an Eye on it you will be fine
Back off it if you hit ECT of 221* but you wont even come close this time year driving around empty
BUMP! To Whitey Ford [Mike's] question.
Who makes the best EGR delete kit?
After reading this thread, I didn't see an answer as to Brands or Dealers for the 'Best EGR delete kit'...
I believe that his is an '02 with 6.0.
I'd appreciate any recommendations for the 'Best' and most complete EGR delete kit Brand and Dealer for a 2006 F-350 6.0?
Thanks to all for input on his site!
The "stealth" delete IS the best delete IMHO. Remove your EGR cooler (or buy a used one) and have your local welding shop weld a couple 3/16" stainless steel plugs in each end. Replace the oil cooler while you are in that deep, they all fail sometime. Hook it all back up as it it was stock. This has several advantages: 1) the exhaust system is supported in the rear is it is stock so you won't crack that $250.00+ Y pipe. 2) it looks stock so the emissions police will be good in all 50 states 3) with the plugs in both ends if it ever leaks who cares? It will never get into your intake and hydrolock or blow head gaskets 4) its cheaper than any kit and you already have the part if you can be without your truck for a day.
Guess you don't have to wonder what "kit" I used.
az
az
azflyman,
Thanks for the 'block-off' suggestion, a method under prior consideration.
What year is your beast?
I have a 2006 which has a y-pipe scoop or diverter to force exhaust gas through the egr cooler. Sound familiar? Some have advised grinding this scoop out to weld a block-off plate there. Was also wondering if an unaltered Y short branch and scoop to egr cooler could burgle turbo feed or heat sync to coolant in blocked egr cooler. I had previously read about negative heat syncing from this method.
Future nationwide blanket emissions action is inevitable as Sam and States capitalizes on the revenue potential of fees and subsequent fines while the global warming anthem plays upon inspection. 8^0
Thanks for any further input!
My truck is an 06 and I did not make the y-pipe scoop mod. I was not all that concerned with getting that little extra umph to the turbo as figured it had enough flow to do the job already. And, besides, if you read through a lot of post you see where the turbo pressure seems to drop when you do an EGR 'delete.' Some have said this is due to the various engine monitoring which adjust turbo pressure based on a number of variables. I saw mine drop two or three pounds after the EGR mod so figured I made the right decision not to put in the extra work. Now it might spool up faster if you did this but I would think initial spool has a pressure component associated with it as well and removing the scoop would help flow rate but have a lessor affect on initial pressure. Not saying you would not realize some improvement but for me it was not worth the effort for what I think would be a minimal gain under my circumstances.
