c6
Old May 30, 2003 | 11:38 AM
86f350diesel4x4's Avatar
86f350diesel4x4
c6
my c6 wont shift into drive unless i hit the gas pedal a few times then it goes into gear. It goes right into reverse. One it gets on the road it runs great. Is it my transmisson filter???
Old May 30, 2003 | 04:00 PM
84-250's Avatar
84-250
c6
check the fluid level. also the color and smell to see if its been abused.
Old May 30, 2003 | 04:46 PM
86f350diesel4x4
c6
already checked the fluid everything looked good there. I also checked the vacumm line at the back of the tranny everything was good there also
Old May 30, 2003 | 05:00 PM
84-250's Avatar
84-250
c6
based on my 78 manual, there are 4 things to check. fluid level,linkage, clutch and band application,or oil control system
Old Jun 21, 2003 | 03:03 AM
archangel's Avatar
archangel
c6
The seal on the forward piston gets hard on older (high miles) trannys and causes the aluminum piston to get a grove worn in it and fluid leaks past it until you step on the gas and the pressure builds up enough to move it up past the grove, then slam, it's in gear.
Just one possibility, and most likely, if it has alot of hard/high miles on it.
Azguy54
Jul 1, 2024 07:29 PM
79 f-150 guy
31
Oct 9, 2009 08:29 PM
sedly
Feb 3, 2009 12:35 PM
ExplorerRon
Jun 16, 2004 12:30 PM
fe97
Nov 10, 2003 11:31 PM
