High Angle Driveline style driveline brake
Looking into a driveline E brake for this spring for getting rig back into action after waiting on a new 1 ton tranny upgrade.
Id like to make it fully road legal with an ebrake as I have rear discs with no e brake and caddy calipers are suppose to be junk.
Ive looked into the HAD driveline brake before but they list you need there "patented" cv flange. I call bull and I'm going to fabricate my own rotor. here is their kit
High Angle Drivline-Call Jesse at 530-877-2875 - My Buildup
I'm thinking of ordering a TSM ,Mb-3 or Mb-4 caliper then make my own stainless 1/4"- 5/16" thick rotor ,9" round with holes to match my cv flange pattern. I would get a local shop to plasma or water jet cut circle.
heres link to caliper
http://tsmmfg.com/7211.htm
Looks easy. I'll fab a bracket and run my stock e brake cable modified to work.
anyone done this before??
link to a homemade setup..
http://www.fullsizechevy.com/forum/g...ine-brake.html
Received 3,106 Likes
on
on
on
i also drove a 66 chevelle home 120 miles from pennsylvania using only the E- brake back in 77 after blowing a brake line in that.
same with the 02. when it tossed a brake pad and spit out the piston on a rear caliper 4 days after i bought it i drove it home about 25 miles on the E-brake.
im going to put it through a voluntary vehichle inspection at a designated garage.I want to have no issues driving around getting harrassed by cops. I'll need fender flares and a Ebrake. Everything else is like new so it should pass. O but I may have to remove air horns. I think those are illegal unless on a big rig
up here if the department of motor vehichles or police pull you over they can issue a vehichle inspection where it has to pass (at a certified garage) to regain to be road legal. cops are idiots and are not mechanics but talk like they are. I want to voluntary get my truck inspected and get the window sticker to shut them up. doing this way i can leave shop ,fix w/e is needed and return. cops way if issued an inspection is tow to and from shop.
