HELP!!
Old Feb 11, 2013 | 03:57 PM
stan2015's Avatar
stan2015
HELP!!
I own a 1993 F150 4x4 and it ran perfectly till I moved the truck 30 feet and parked it and that was the last time it ran. When I tried to start it a couple weeks later all I got was a click,so I charged the battery,changed starter relay,even the starter! I swore it was locked up! But it's not so any suggestions? I'm at whits end! Thanks very much
Old Feb 16, 2013 | 07:00 PM
UNTAMND's Avatar
UNTAMND
Hey man. Sorry no one has replied. Have you had any messages to help.
Back to the front page.
Have you gotten the truck running yet.
Did you pull out the plugs a d try turning it over.
Did it run good or bad when you moved it.
Is all the coolant in the radiator still.
Old Feb 16, 2013 | 08:05 PM
HD's Avatar
HD
One thing you might try looking at is the battery cables themselves. A long while back I was having starting issues like that and pulling my hair out. Then I learned that even though a battery cable looks good on it's end, the wire under the sheathing can be corroded and green as Popeye's supper. This is exactly what I found. I replaced the cables and it's worked good since.
If your battery cables are original, I would take a very close look at them.
Chris
Old Feb 16, 2013 | 08:35 PM
kermmydog's Avatar
kermmydog
Are you sure you battery is not shorted inside. I would have the battery checked also,
Craig
Old Feb 17, 2013 | 06:44 AM
OldGrayMare's Avatar
OldGrayMare
Check to make sure the starter relay has a good ground where it bolts to the inner fender. You may have to sand it a little .
jackstraw
Jun 22, 2013 10:57 AM
seths89f150
15
Feb 24, 2011 05:51 AM
tetraruby300
Feb 21, 2005 11:19 PM
crack
Nov 8, 2004 07:47 PM
billsmithhd
1978 - 1996 Big Bronco
Jun 24, 2003 09:40 AM
