'95 F350 Transmission Problems
I've got a 1995 automatic gas F350 with about 186,000 miles on it that I'm having a transmission problem with. It has been sitting for about a year, runs great in park and neutral but when I put it reverse or drive, it wants to kill the engine. You really have to find a fine line between gunning it and feathering it to keep it running but it only acts like this for 10-15 seconds and its like nothing ever happened, running like a dream. I've tried running it and driving it for awhile to see if it all just needed to be warmed up after sitting for about a year but it continued to do this every time I shifted from either neutral or park to either reverse or drive. Any suggestions?
Thanks!
Trevor
Thanks!
Trevor
Chance trans has nothing to do with it, might just be a sticky IAC from sitting. Not opening/cycling fast enough to prevent rpm drop when first put in gear.
Take a minute if haven't run the self test, always best place to start. If get a system pass so be it, getting system pass/no stored codes is just as helpful as getting trouble codes/failed self test.
Fuel Injection Technical Library » How To Run a Self-Test
Fancy code reader handy yea but not necessary.
Rynopwr
02-24-2012 12:08 AM
