Getting a DP Tuner - Should the stock exhaust system be upgraded?
2003 7.3 F250 CCSB. I am going to order a DP tuner from Riffraff along with a 6637 filter kit.
I don't do any serious heavy towing, nor plan to for an extended amount of time in the near future.
Should I upgrade my exhaust or will stock be fine? There are no DEQ type requirements where I live.
There is mixed emotions about this... Stock exhaust will be fine in my opinion. A 4" is really nice to have though. Your budget should have the most say in your decision. If nothing else ditch the cat. if you have one and muffler if you can deal with and or like the sound of a straight pipe
Probably a stupid question but do you have any gauges in the truck to monitor EGT's Etc? I would invest in those first if you dont have them! IMHO I do not like the straight piped exhausts. As said above "Ditch the cat", you can get a few $ at the scrapyard for it too! I think after a while on long trips the straight pipe gets really old really fast, especially in an excursion!
Received 3,103 Likes
on
The stock exhaust and a muffler delete (or replace it with a straight through muffler) increases the flow very much.
Some say there is no difference between a 4" and muffler (which they are all straight through but some are louvered and some are perforated mufflers) and a straight piped stock exhaust.
As a first hand experience for you, my brothers psd has stock exhaust and dp tuner (along with gauges) and 80e will get super hot on some good pulls. The stock muffler is too restrictive for egt to stay safe.
Another first hand example, one of my CCLB trucks has 4" exhaust and I added a second (perforated) muffler, and it is very quiet. I honestly think it sounds like stock and with my 80e I can push over 30psi and egt stays happy.
I've blown (get it?) cash at muffler delete and a 4" exhaust with stock sticks and a DP. The 4" is the call... but after a full set of gauges. If you have $400 disposable income to spend, I would get AutoEnginuity before the exhaust upgrade, though. The 4" does help, but not as much as finding all the little things wrong with the truck that you don't know are there.
The two biggest power adders before my Stage II sticks? DP 60E and AE. I'd even go so far as to say that at the age of these trucks, AE should be used to get the truck to 100% before you chip... but I'm ****. The last link in my signature will help with making sure the truck is running right.
I would recommend to upgrade your exhaust for better flow, but it is not completely necessary.
The order most people go with is intake/exhaust, then gauges and a chip.
when I owned my truck I did what most do. upgraded exhaust. gauges etc.
I am not fully sold on the exhaust, but since I had it, I didn't even think of it again.
gauges FOR SURE. I would actually do Gauges FIRST to get an average reading. then you know if you will need them or not.
if you do up grade to the 4" you should notice a little difference in temps.
also I didn't tow a lot. or many heavy things. so that is why I am not sold on the 4".
now I have a van and will probably not do exhaust cause clearance seems a little tighter than the trucks (I think). but that is just me. plus I am saving for up pipes and gauges first
I also didn't have DP. just a plug in programmer and set it for 60 eco. and left it.
to each there own and this is only my opinion
If your truck has a CAT you NEED to keep it. your going to need it at some point for an inspection. It is very hard to find a used cat. you will have to pay ford BIG $$$ for a new one. I believe, someone will correct me.. $1500 to $2500 for a new cat from ford. Put the new exhaust on and keep the cat in your garage just incase..
I was under the impression that (other than ca) these trucks were not required to have a cat.
But if you're concerned that you need a cat (I'd go to the inspection station and ask if your class of truck requires a cat) you can buy a diesel specific cat from summit for 260
MagnaFlow Diesel Converters - Mobile SummitRacing.com
In ME and PA you are not required to have the cat.
I took the cat off an e99 manual trans truck and it was perfect. So just check it out and if its good then continue using it.
