1952 f 8 power train upgrade?
The F8 has a slightly longer engine compartment than the F1-6 series, so most any, more modern OHV engine will fit in there. No engine swap would be considered easy, but certainly within the capabilities of most mechanically inclined persons. It all depends on what you want and what your skill levels are.
Oh, by the way, welcome to the forum!
FoMoCo was planning to install the V12 engines used in 1940/48 Lincoln's in the new 1949 Lincoln's, but at the last minute, the 337 flatty truck engine was used instead.
There are differences, internally and externally. 1949/51 Lincoln's were available with 3 speed manuals with/without O/D and 1950/51's with Hydra-Matic.
Thanks merc and number, it gets shipped up to my on the 13th . The plan is to use the truck in parades and to work it here and there !pull a small excavator 10 500lbs I'll be the 3rd owner the last owner has owned it since 63 he's the one that said it was a Lincoln in it.
It's not ever going to be a show truck but a want it to look nice ,work well as a truck and be safe
Nomally, the last thing I would EVER do is dispute any of your info re What's what in Ford trucks but I think you'll find that 1951 was the last year for the 337 Flathead in both the Lincoln car and the Ford trucks. The O.H.V. 317 was introduced in the 1952 model year in both vehicles.
You bought an F8 with a 337 V8 flatty truck engine, 337's installed 1948/52.
I would do modern front and rear axles (so you can use modern 22.5" radial tires, wheels,and modern brakes and a modern pwr steering box) , a Cummins 6BT (12v) and a 10 speed Road Ranger.
ymmv.......
DON'T forget to post pictures! We love pictures!!
Rick
on
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
The best photos and videos | Photobucket
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html
1. Login to FTE.
5. Click Upload.
Welcome to FTE!
Hope that helps.
Dale: Typo! I know that 1951 was the last year for the 337 flatty. Usually I read my posts after I post them to edit out goofs, missed this one. You'll notice however that I got the Lincoln apps right.
The 279 and 317 OHV V8's were Lincoln derived Y blocks installed in big trucks. You won't find any Lincoln w/a 279, 1952/55 Lincoln's came with 317's.
302/332 also Lincoln derived Y blocks, installed in 1956/63 big trucks. No Lincoln came with either engine.
