IM STUMPED
Old Feb 6, 2013 | 02:42 AM
twwtruck's Avatar
twwtruck
IM STUMPED
ok i got a 78 f250 with a stock 460 i found a good deal and put a victor 460 in take and holley 770 vac secondary carb on.now when i get into in park or with a load it falls on its face. i have downsized jets several times and changed the secondary spring. still same thing no vaccum leaks changed power valve nothing. any ideas??? is the intake just to much for all stock motor?
Old Feb 6, 2013 | 11:53 AM
cbakker's Avatar
cbakker
That might be breathing a little hard for a stock motor. Especially if you have stock heads.
bigdan1979f-250's Avatar
bigdan1979f-250
You might double check and see if your vacuum source to the carb is a regulated ported vac source or manifold vac port. If you are running off of the manifold pressure, any change in rpm would affect it and change your timing advance. The regulated vac port runs off the carb and is less affected by change in rpm. Not saying it is not affected at all, just not to the extent that the manifold vacuum is. Should be a lot smoother too. So my advice is to make sure you are running off a carb regulated vac source. I dealt with the same problem on my 460 and thats what the problem was, however I have an Edelbrock, but the principle is the same.
Old Feb 6, 2013 | 11:17 PM
85e150's Avatar
85e150
I looked up the Victor 460. All I can find are single plane manifolds good for 3500 to 8000 rpms. If that is what you have, take it off. You will never be able to make a stock motor run worth a poop with that manifold.
http://www.edelbrock.com/automotive_.../2000/2966.pdf
Old Mar 10, 2013 | 05:34 AM
twwtruck's Avatar
twwtruck
Yeah I ordered a performer intake for her gonna see how she runs now
BainbridgeBrewer
Jun 17, 2016 09:17 AM
TheNomad
26
May 28, 2008 06:09 PM
White_Knight
Aug 8, 2003 01:27 PM
travlinman66
Jan 22, 2003 10:09 AM
dpoelstra
Oct 31, 2002 08:18 AM
