1995 F53 motorhome chasis
Hello everyone, I need some help with my 1995 F53 motorhome chasis. The problem is the turn signals stop flashing when i apply the brakes. Everything works as it should until i hit the brake pedal then the turn signals stop flashing. Can anyone help me with this thanks
Keeping you grounded...
Check the ground point(s) for your stop/turn/tail lamps. It (they) should be somewhere near the rear of the vehicle; probably a green (if not corroded away) machine screw securing one or more black wires. It is also possible that your multi-function switch on the steering column has failed. Check the grounds first: Easier & cheaper fix.
dn.
dn.
dn.
dn.
