LED Bulbs
I'm posting from my phone so maybe someone else can pitch in. It's really simple though. The taillight bulb has 3 wires. Ground, low power (running light) and high power (blinking light). Just tap into to blinker wire and ground wire and your good. It's going to be the 2 outside wires that come out of the plug. Leave the center one alone.
The resistors I use. They say they do get hot but mine just get a little warm to the touch.
http://store.ijdmtoy.com/50W-Load-Re...d_resistor.htm
Well, if they really are 50 watt, that's at least good design practice. Resistors should run at about half their rating, and 12 v x 2 amps ~ 24 w.
I have read elsewhere that they make LED flashers that run on the lower load. Unless they use this same trick internally, that might be a better deal -- provided that they're reasonably priced.
just a thought,
hj
just a thought,
hj
