You didn't really state what you are trying to accomplish. Just my opinion, but that is over kill on the distributor. You can get a stock rebuilt one for a fraction of that one.. And there is nothing wrong with a stock cast manifold.. Unless you are building an all out engine...
Sure. That's a more expensive option but it is easy to tune and a well known brand.
If you don't want to spend so much, go to the parts store and get a rebuilt distributor for a 1964 F100. It will probably be a Motorcraft which is good because you can find different points cams for tuning and you can convert it to a Duraspark trigger pretty easily, if you wish.
The red ones are for a tea pot. Those require an adapter for a newer carb.
The other two will allow a modern carb to bolt directly.
The aluminum one is the best aftermarket manifold there is, and simply the best manifold period.
The large base iron intake is the best factory intake there is.
Get one of these. For a stock or mild motor, go with the iron intake.
If. I'm going to need to buy a carb then I need a different distributor and manifold .... I would like to reuse it on the motor after I brake it down and build it up .
I need the room on the front of me motor for a compressor so I plain on cross over to go bye bye! How big of a exhaust pipe is to big ,before losing to,much back pressure? I plan on putting one like this on it
The exhaust is something I'm not sure of. Everyone has a different theory on how much back pressure if any at all is needed. I've read several articles on it and have never came to an exact conclusion.
WOW! I've never seen that compressor setup, what is that for
The biggest you can use with rams horns is about 2". The bolt spacing is too narrow to go any bigger unless you get fancy with tapered pipes. 2" will be plenty.
I m putting air ride rear tandem axles on with air brakes !
