video of truck dying while driving
I am posting a video of what my truck is doing while on the road. It sets a 1211 code when the cel comes on, but no code when the wts light comes on while driving. I am stumped although I am leaning toward a new ipr or hpop. I have checked for shorts and bad grounds, wiggled wires, checked icp sensor, replaced cps, checked connections at idm and pcm, even checked ignition switch. If you watch the video you will see that when the cel comes on, the power dies down and it goes into lope mode. When the wts light comes on, I just lay off the pedal and it goes away. I apologize for the quality, but it's the best I could do with my phone while driving.
http://db.tt/AMjTqxVa
I agree. Not sure if it makes much of a difference, but when the CEL comes on the volt meter takes a dump. I have an old Harley that burns up stators and runs like crap when it can't put out enough electricity to keep up with all the needs. I wonder if it is something electrical...
From the manual :X7 KOER ON-DEMAND DIAGNOSTIC TROUBLE CODE (DTC) P1211
DTC P1211 indicates that injection control pressure was above or below commanded desired pressure during self test mode.
Possible causes:
incorrect oil or viscosity
poor oil quality
gel fuel/no fuel
low fuel pressure
damaged IPR valve
high-pressure oil system leak
damaged high-pressure oil pump
damaged PCM
Does the windshield leak?
Have you done a buzz test to see if there are any IDM codes ?..
Possible causes:
poor oil quality
gel fuel/no fuel
low fuel pressure
damaged IPR valve
damaged PCM
Thanks for the replies. Just got home from work and also took it to a mechanic who scanned it. The truck is getting hard codes for the icp, cps, tps and a few others. Mechanic thinks it is something electrical because the sensors have already been replaced. Buzz test came back good. He wants to start checking for shorts. He also said the pcm could have in internal short. No windshield leaks.
She's got almost 233, 000 miles on her.
