Stinky's Stick-up
#106
I am curious to know how you don't wipe half the loctite off on the injector walls when installing the cups? I mean it is a long way down there with not much wiggle room for the cups. Or do the cups have quite a bit of room when going down the injector hole? I would be tempted to smear some loctite on the head itself around the cup mating areas.
#107
#108
The last 5-6 cups I wasn't as concerned with, much quicker. The amount of compound that is actually left on the mating surfaces is very small. Nearly all of it is pressed out as the cup seats, then the excess is wiped away.
My .02 anyway.
#109
I'd be waaaay more concerned about contaminating the sealant with brake cleaner!!!!!!!!!!!!!
I will admit, your **** retentiveness is quite comical. Thanks again for sharing!!
Great tips Tug. Just to add 1 thing, the loctite compound that clay carries will not cure where it's open to atmosphere. Atleast that's what I assume from reading the back of the bottle. There was a statement about the air inside the bottle keeps the compound from setting up.
#110
Given my aversion to hanging family photos and installing plumbing and a fridge under Stinky's hood... can you blame me for going all out on this? I can't even get a bolt to stay in place, unless I do it just right.
Tips: Installing injector cups involves long-winded bolts. I use a cordless drill (and judicious use of the trigger with a wet cup) with a U-joint for the long free-spins up and down. I have a magnetic sheet with all my necessary tools right there to reduce the time it takes to work with a wet cup. 4 mm ball-end T-Allen speeds up the bolt-down and removal of Clay's insertion/removal tools... the 4mm ball-end Allen works even faster when it's a 1/4" hex for my cordless drill. I mist the insertion tool with lube before I put the cup on it and clean the cup. The tool removes easier after insertion and it cleans faster each time. I measured from the head of the insertion bolt to the plate on the first good cup seat. Subsequently measuring the bolt height with each cup prevented me from leaving two cups a little too high while inserting. "Oops... not enough. A couple more pulls on the socket drive ought to do it." They are either all wrong or all right. Wagers?
#111
In response to my question during the group part of an oral exam, an examiner once told me: "There are no stupid questions, only stupid people asking questions!"
So with that in mind, I ask: Does the fuel port in the cup have to/should be aligned in any particular direction to prevent cavitation or to be more efficient or whatever?
#112
Tug, I saw that drill being used and I really want to get one for my drill. My wager is they are all going to be fine.
Tim, I'm not sure what you're referring to. The cups are symmetrically round and have no additional features. The fuel port in the head is above where the cup seats. This may help.
#113
Not a stupid question, doing cups is one thing im dreading when the time comes....trying to read up, and thought the same thing..
#115
Hmmm..... The coolant not only surrounds the cup (which I knew), it's in contact with the exhaust port wall. That explains how getting up to highway speed instantly turns my "heater" into a blast furnace. I'm curious if I can find a bigger copy of this image... or other useful images regarding cups.
Valentine weekend. Let's see if I can get Stinky ready for a road trip and address a few letters of the alphabet. The wife and I are anxious to cross that TLN off the list.
#117
#118
#120
