Replacing TPS + MAP + Fuel Filter = New Truck!
Old 01-31-2013, 12:24 AM
GuitarJesus's Avatar
GuitarJesus
GuitarJesus is offline
Can't believe the difference after replacing the sensors and fuel filter. No sputter, smooth, could be just me, but I feel like I'm getting a better shift point also.
Next up for easy upgrades, msd cap, coil, and ford racing wires.
Anyone got any other simple yet effective upgrades for me?
Old 01-31-2013, 08:10 AM
pfogle's Avatar
pfogle
pfogle is offline
I'm willing to bet your sputtering was a clogged FF, the TPS tells the trans when to shift, and the MAP sensor kinds tells the computer how much vacuum there is in the intake.
Old 01-31-2013, 09:39 AM
GuitarJesus
Its just weird slight bogging down before I replaced everything. Replaced the TPS and the idle was horrible. Up and down between 250 and 1250 RPM. Replace the filter, just a tad better. Then replace the MAP and bam! Everything is perfect. Guess with all parts old, the computer found a way to just chug along.
Old 01-31-2013, 10:55 AM
DPDISXR4Ti's Avatar
DPDISXR4Ti
DPDISXR4Ti is offline
Interesting, as the MAP has no moving parts and is typically rather reliable. It would be interesting to do some forensics on that part and see what was failed/failing.
Old 01-31-2013, 02:11 PM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
The best bang for the buck is upgrading the exhaust, nothing will give you bigger gains for the same money.
Old 01-31-2013, 02:58 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
You won't really find anything inside of it. Just a sealed pressure sensor cell and some electronics.
Old 01-31-2013, 05:01 PM
GuitarJesus
Oh I know. Just funny how much of a difference it made.
oakland25164
05-04-2010 11:16 AM
cougar190
01-27-2008 10:44 AM
roller_steve
13
12-02-2006 07:07 AM
tyson1992
11-27-2003 09:11 AM
SleepySam
Bronco II
03-12-2003 04:17 PM
Quick Reply: Replacing TPS + MAP + Fuel Filter = New Truck!
