new o-rings for my injectors
Old 01-14-2014, 05:26 PM
Jerry Chaney's Avatar
Jerry Chaney
Jerry Chaney is offline
ok, now what. viewing some of the video's on line they talk about turning the crank before insertion of injectors, for how long. can I soak up remaining diesal out of injector bowl with rags? is that it? thanks everyone....love this site
so I have to get anything that falls under injector cup, fuel, oil.
Old 01-14-2014, 05:52 PM
HKusp's Avatar
HKusp
HKusp is offline
I leave the glow plug out, put the valve cover back on with a bolt or 2 and bump the starter a few revolutions. If you have someone helping, you can just leave the glow plug out and have them hold the rag over the hole. there is some pressure but not a lot. It will blow the oil out of the hole.It works well.
Old 01-14-2014, 06:15 PM
whitetmw's Avatar
whitetmw
whitetmw is offline
+1 - Although, it will fly about 10 feet onto the vehicle next to you if they're not covered. Don't ask, the windows was down.
Old 01-14-2014, 06:16 PM
Jerry Chaney
ok, thanks man. so what exactly is under the injector cup. newbe here. don't really know anything, but learning as I go. I wish I could look at a cut-away of a diesel motor.
Old 01-14-2014, 06:21 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
LOL. I discovered the same thing yesterday. Didn't quite make it ten feet though, I was turning over slowly by hand.
Old 01-14-2014, 07:21 PM
Jerry Chaney
so I read that I should change oil after injectors are back in, really?
Old 01-14-2014, 07:32 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
It seems like a good idea to me. Some fuel will run into the cylinder when you pull the injector, and it's bound to get into the oil pan.
F0rdF0rever
22
09-08-2012 06:22 PM
MustangMatt96GT
34
11-14-2009 10:43 PM
Bigfwt04
05-21-2009 09:52 AM
WA.Ranger
22
03-15-2009 09:27 AM
76Econoline
11-13-2008 07:16 PM
Quick Reply: new o-rings for my injectors
