Hi can anybody tell me were I could buy new spindels or good used ones for a F100 stepside Twin I Beam 1965 or even no what else may fit this application. Thank You Ron.
What year in the 70,s will be a direct fit to the old I beams I was going to buy the disc brake conversion kit but this sounds easier and cheaper to get. Thank You.
get complete frontend from 73-79 .get ibeams,radius arms, draglink,proportioning valve,booster, master cyl. and front brake lines. direct bolt in. i gave 150.oo for the last one i got from local junkyard
Unless the i beams are bent there is no reason to replace them. Spindles and all accessories are a direct bolt on to 65 66 beams with the correct year kingpins.
