will a 90 f150 manaul pull a car about 1000 miles
on
I used to have a 1990 F150 RC SWB 4x4 302 M5OD 3.55 and I towed trucks and small tractors all over Texas and some of Ark (on a 16' trailer) with it. The Ford rated tow capacity was 3500 lbs, don't think I was ever under that but it still had the original clutch in it at 225K miles. Take what you will from that.
this is a noob question but what speed were you able to go and can you go into OD
Thanks
on
Dont forget. he has no hills where he was towing
If you're looking at a U-haul, be careful what you do. I don't think U-haul rents any car dolly's that are rated to pull a truck. I think they have a maximum weight of 3500# or so for the load.
I remember looking it up when I was contemplating pulling my truck... If I remember correctly, the tires would rub, but it would fit assuming there's nothing on the dolly that would impede the hubs from hitting (assuming SRW Dana 60)
Yeah i was gonna do that, say im pulling a small car. i dont need to go far.
My dad always taught me--rules are ment to be broken!
I hate to say "if you're going to run 70mph" because you should always do this anyway. But especially if you plan to run faster than 65mph (and with the distance you're traveling), make sure your trailer tires and wheel bearings are in nothing short of top notch condition. Think about it...half of the blowout incidents you see along the side of the road are the boat, camper and utility trailers that spend 360 days of the year outside in the sun, with the cheap Chinese tires rotting away. Don't be a statistic.
#28
on
That right there says it all IMO, this truck is not properly equipped for towing so you're just asking for trouble. And like Brad said you're not going to get more tan 8-10mpg towing anyway and it'll be the slowest thing on the road so why not just take the 1-ton and be safe.
#29
A 2wd Manual f150 300 6cly is rated to tow.....
w/2.73 gears 2,100lbs
w/3.08 gears 2,300lbs
w/3.31 gears 2,900lbs
w/3.55 gears 3,600lbs
A trans am weighs about 3500lbs. So unless the tow dolly weighs 100lbs, you would be over weight by Ford specs
If automatic the following applies
3.08 gears 4,700lbs
3.31 gears 5,200lbs
3.55 gears 5,700lbs
If tyou go with a tow dolly, I would leave A LOT of room between you and the car you are following since they have NO BRAKES. if using a trailer Make sure it has WORKING BRAKES
ALSO, I hpe you realize the 6cly towing another car is going to get about 8-10mpg and be slow as hell doing it
3.08 gears 4,700lbs
3.31 gears 5,200lbs
3.55 gears 5,700lbs
he put in a stage two clutch though so that should help also where did you get your numbers my auto 92 with 3.08 are rated to tow 0-6200 pounds this is on the door sticker and in the owners manual (Axle code 18)
#30
on
I suspect those numbers are from the owners manual, the numbers in my '90 owners manual are slightly different but close, and yes tow ratings are lower for manual transmissions vs autos. The calibration decal on the drivers door pillar also has an axle code which will tell you what gear ratio the truck has, this really doesn't matter however because the load you plan to tow is above the trucks rating for all gear ratios except 4.10, so not only is this not advised it's illegal so you better hope you don't get stopped by a state trooper... those guys have no sense of humor.
