Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
Q? for tech guru's/ 2009 Edge
Old 01-15-2013, 06:49 AM
Desert Don's Avatar
Desert Don
Desert Don is offline
Received 4,599 Likes on 1,639 Posts
My daughter has a 2009 Edge with about 50,000 mi on it. It will randomly either crank and not start, or just not crank at all. She has had it to two different dealerships about a dozen times; one, where she bought it, and the other closer to her home. The last time she was there, they just replaced the battery and sent her on her way. I know this is probably like chasing ghosts until it completely quits; but thought there might be some common problem to look for. Thanks in advance for any and all responses.
Old 01-15-2013, 11:16 AM
BAD RONALD's Avatar
BAD RONALD
BAD RONALD is offline
Have you experienced the condition since the battery replacement? It's not way out of line to replace an original battery in a 2009.
Old 01-15-2013, 01:10 PM
Desert Don's Avatar
Desert Don
Still continues----Yep.
Old 01-15-2013, 08:24 PM
JWC 3's Avatar
JWC 3
JWC 3 is online now
Ck RF keys . Ck for others on key chain . If equiped with coded keys , others can interfere .Try a different key ,see if problem still exists .I have seen problems with multiple vehicle keys on the same key chain .
Old 01-15-2013, 08:36 PM
BAD RONALD's Avatar
BAD RONALD
Key chips can definitely cause interference. Especially with intermittent failures. Good place to start eliminating possibilities.
Old 01-15-2013, 08:37 PM
Desert Don's Avatar
Desert Don
Thanks for the replies, folks. But she just called me--- traded the damn thing off.
bronkntrukholik
08-04-2013 12:40 PM
hochelaga
Electrical Systems/Wiring
04-11-2012 11:22 AM
danorules
2004 - 2008 F150
08-01-2010 06:42 PM
Quick Reply: Q? for tech guru's/ 2009 Edge
