New rebuild runs like crap
If #8 is clean, completely clean with no fuel at all, then I'd suspect the injector isn't firing. Either the plugs bad, the plug is not getting power, or the injector itself is bad.
Also you should figure out why it overheated. More than likely you need a new fan clutch and the radiator should be cleaned (at a radiator shop) or replaced. You can't work these trucks "too hard", the cooling system was designed to cope in the most extreme conditions at full load.
DutchmanAZ
24
07-28-2017 08:43 PM
Zac2zac2
26
12-02-2014 10:39 PM
nickdellamore
08-17-2010 09:19 AM
