OT (a bit) BIO Diesel as a cleaner
Old 01-28-2013, 06:42 AM
Supercab's Avatar
Supercab
Supercab is offline
Wink OT (a bit) BIO Diesel as a cleaner
Has anyone used say 99.9% Bio-Diesel as a cleaner on grease or flash rust?
reason I ask is I'm trying to find something cheaper than Boesheild's "Rust Free" to clean up some flash rust on my truck and my Mustang and thought that from what I've heard Bio cleans very well.....
I can get Bio 99.9% locally for about $3.75 per gallon now as opposed to $60.00 for a gallon of "Rust Free"
Old 01-28-2013, 08:23 AM
izzybird's Avatar
izzybird
izzybird is offline
I made a few small batches of bio a couple years ago and it was a very good degreaser/solvent. Not sure about the rust part though. Bump for you.
Old 01-28-2013, 08:44 AM
binuya's Avatar
binuya
binuya is offline
Not sure where your 'flash rust' is located on your truck, but biodiesel is not the best choice for removing it. It will work, but a lot slower at breaking down rust than petroleum based product. Besides, if the flash rust is on your chassis, you'll want to be careful about getting any on or around rubber parts like seals, bushings and the like. It will eventually dissolve them. If this flash rust is on your body panels, then you'll need to be careful about getting too much on there as it will eventually dissolve your paint.
Old 01-28-2013, 10:07 AM
Supercab's Avatar
Supercab
Supercab is offline
Thanks guys!
Has anyone experianced any type of fuel system failure due to the use of commercially made BIO?
Old 01-28-2013, 10:34 AM
Fat Diesel's Avatar
Fat Diesel
Fat Diesel is offline
Yes. Rubber fuel lines will leak. Twice I've had BIO create pin holes in the middle of a line, away from fittings. Get 30R9 hose with a Teflon liner.
Old 01-28-2013, 11:31 AM
clem1226's Avatar
clem1226
clem1226 is offline
I have ran a few thousand of gallons of commercial B100 through my 100% stock 2000 superduty fuel system without issue.
I am not saying nothing will happen, it just didn't to me.
Old 01-28-2013, 12:08 PM
binuya's Avatar
binuya
binuya is offline
Originally Posted by Supercab
Thanks guys!
None. I had noticed your other thread about the the pickup foot possibly having come off. For what it's worth, I did the in tank mods a little over a year ago. There was absolutely nothing in there to indicate that biodiesel had degraded anything inside the tank. The pickup foot was in fine order, and as a matter of fact, the mixing screens were spotless. I was sort of hoping to find some sort of junk in there, especially after hearing about others experiences here, but everything looked great. I have run over a couple thousand gallons of B100 over the last several years.
Old 01-29-2013, 06:57 AM
Supercab's Avatar
Supercab
Supercab is offline
Thanks guys for the replies! I appreciate everyones opinions!
-Getting ready to drop the tank here soon and do the Harpoon, Hutch, remove the restrictor in the fuel filler neck, and add the S/D kit.
Old 01-29-2013, 08:58 AM
MTDewX's Avatar
MTDewX
MTDewX is offline
careful on getting any VO on any asphalt. it will eat it away. I am assuming BIO would be the same.
didn't want your to have holes in your drive way if you happen to have an asphalt in your drive way. it will eat it away over time.
I spilled some VO at my folks in OR. there is a softball size hole, and thats in the Portland area that RAINS a LOT.
jvmcc
08-26-2014 07:54 AM
JP808
Paint & Bodywork
01-23-2012 11:03 PM
dspeer75
Paint & Bodywork
02-22-2009 11:00 AM
Bigdaddy29384
Paint & Bodywork
03-19-2006 08:17 PM
biggreen78
Paint & Bodywork
10-25-2004 01:17 AM
Quick Reply: OT (a bit) BIO Diesel as a cleaner
