93' Bronco XLT with some wheel well rust..
Starting my mini write-up on patching up my 93' Bronco XLT..
Going to try and use Bondo Glass for this.. if not a small patch will be made up..
The vehicle.. Black and Smoke Metallic (Gray)..
The rust area(s) on top of both rear wheel wells.. (normal stuff)..
I tapped around the area and nothing collapsed.. so I'll trim/grind off some and see whats up..
Suggestions or tips are appreciated..
Have you considered patch panels?
1987-98 Ford Pickup/Bronco Upper Rear Wheel Arch (Fleetside Only) Passenger Side
@ khadma I have considered the panels.. but want to do the fiberglass thing first and see what happens..
Well today I started on the passenger side (shown above)..
After some cutting with the dremel the hole opened up.. (also did some Rustoleum Rust Converter before I went to the next step..)
Then after some magic with long strand fiberglass hair.. and yes their is still a space between the quarter panel and wheel well panel.
52 USCG Panel
61
01-02-2017 06:27 AM
Brian Young II
29
11-12-2015 12:49 PM
