difference in axle size?
Old Jan 27, 2013 | 12:16 PM
69highboy69's Avatar
69highboy69
Okay so so I was driving down the road and my hub and outer bearing on my from axle blew out... wondering how I tell if its a heavy duty dana 44 or not. my pick ups 1969 f250 highboy its a close knuckle low pinion 44 just wondering if its HD so I can rebuild it. No axle tags found on it... any info would be greatly appreciated
Old Jan 27, 2013 | 12:37 PM
HIO Silver's Avatar
HIO Silver
I don't think Dana have an axle tag. They use a stamped "Bill of Materials" (BOM) number stamped on the housing.
Look up the BOM number here: https://www.ford-trucks.com/forums/1...l#post12739050
Scroll down to the Dana 44 section for info.
Old Jan 27, 2013 | 01:01 PM
montana_highboy's Avatar
montana_highboy
Look on the back side of the steering knuckle...
8 bolts around the knuckles (small) ball = standard D44
12 bolts around the knuckles (big) ball = heavy duty D44
Old Jan 27, 2013 | 02:59 PM
69highboy69
Alright sweet, thank's for the help.
Old Jan 27, 2013 | 04:31 PM
1972RedNeck's Avatar
1972RedNeck
Which is it? I'd like to know if you don't mind.
Old Jan 27, 2013 | 06:43 PM
willowbilly3's Avatar
willowbilly3
Also you should be able to tell by the front axle GVW on the body plate.
Usually (maybe always) the light duty has a tapered hub and a smaller lockout, The heavy duty has a straight hub and is bigger, same as all the 70s 3/4 ton chevys, lockout parts even interchange between chevy and heavy duty Ford, just the color of the plastic center was different.
Old Jan 27, 2013 | 07:34 PM
RichS2659's Avatar
RichS2659
If I remember right, the hubs were made by Warn with the Ford oval on the dial. My 70 CC has a HD, and my 76 CC has a LP 60. But I can't tell what GVW it has as the left door has been replaced, and the warranty/safety sticker is blank except for the vin.
Old Jan 28, 2013 | 08:01 PM
69highboy69
It's an HD, I had warn premium hubs do they have a warranty?
snowbrdjnky
Aug 31, 2009 10:01 PM
BiGgReEnBEAST
Dec 11, 2006 10:06 PM
cies_69truck
Nov 12, 2002 08:05 PM
4x4akvan
Oct 27, 2002 04:09 PM
petem
Oct 12, 2001 03:56 PM
