radio replacement
radio replacement
iowa here
am thinking about putting a radio/cd/mps player in my 7.3
is there such a thing that will fit right into the current
radio/cd player space?
the lights went out a long time ago that tell me what station i was on.
but everything still works
would be nice to have an mps player
thanks
dave
thanks
dave
you can get a nice double din radio in the dash with slight modification to the bezel......just a little sanding the top and bottom edges....here is a pic of the clarion i got.....has a usb and mp3 jack right up front and the bluetooth is built in and works well.....not too fance but simple and i love it.....
Redirect Notice
Redirect Notice
From what I've been able to find out so far, looks like there is some sanding / dremel work needed to be done on the opening. Talked to a guy today who told me the dashboard has to be removed to swap out radios and he also said the opening would require cutting. I'm a novice on this and I'm trying to get as much info as I can. The radio I have is stock with 6 cd changer in it.
The dash is a lot easier to remove than installing the stereo (depending on how deep the unit is). If the dash is a stumper, I'd recommend getting a pro to do it.
- Double-Din is the way to go. The unit won't last forever, but I suspect the Double Din format will be around for a long time because it makes a great video screen size in the dash. This means the next Double-Din unit will fit if you do it now.
- I have a Dremel-like tool with a bit that's made to carve plastic like cheese. Just make sure you go easy, you'll have to stare at any mistakes for years to come.
- Pull the whole dash apart. You'll have more room to work and you'll be less likely to damage something aesthetic.
- Get the Ford stereo pigtail, then get the wiring diagram to match up with your stereo - documentaion before wiring really helps.
- I used Scothlok filled UR2 connectors because wire nuts permit corrosion over time and fall apart from vibration.
- If you back up to a trailer and value your spouse, I urge you to consider one.
- I also stress the SD card. A CD holds 700 Meg of music, a DVD holds 5G of video/music (about one 2 1/2-hour movie) - but my SD card holds 8G of everything. SD card - more capacity, no moving parts, no need to change "disks", and no skipping over railroad tracks. Many people want an Ipod interface, but an Ipod is just digital storage for music and the SD card will do this without wires hanging out.
- The bluetooth (phone interface) feature is sometimes included with these and sometimes they are an add-on.
