1987 6.9 IDI Lift Pump Problem ???
I have a 1987 F250 6.9 IDI and having a problem with it! It will sit and idle but when a get about a 1/2 mile down the road it dies and takes a couple cranks to get it started again. Some people are saying its the Lift Pump, but I wanted to get some more info before replacing it.
first thing is the filter.
you can test the lift pump by holding open the little schrader valve on the filter head while cranking, should produce 1/3 pint per 10 seconds of cranking. if it does and it isn't leaking, then your pump is good.
if your truck has dual tanks, does it happen equally on both tanks? if yes, then the problem is forward of the selector valve. if not, then it could be a problem with the pickup inside the tank.
also look for sections of rubber hose that might be getting old and soft enough to cause problems. in stock form i believe the only rubber in the fuel supply is the piece that connects to the lift pump, but check the whole line for any damage or anything weird
Chris754
34
03-18-2019 11:31 PM
wburge
10-17-2011 05:06 PM
6.9lXLTf250
13
07-12-2010 12:28 AM
