Anyone have 35's on a leveled truck?
I run 315's-75-16 with 2.8" levelling kit, I had to space my bumper slightly, and pull back the fender liners, due to wheels.
I guess I don't really have a good pic of the bumper to fender difference, but you can kind of see it in this pic.
Here's a height comparison next to a stock F250
Having to space the bumper, I didn't like that much just because it doesn't line up, and I actually like the way 285's looked better on a stock wheel, so I may remove my spacers until I decide to maybe go with an aftermarket bumper.
BTW Trey, haven't seen(or paid attention) your truck since these last rounds of updates cosmetically. Looking really good.
I guess a 4 inch lift is in my future. I can not remember if I have 16 x 9 or 16 x 10. No rubbing on the leafs or the passenger side at all, but the drivers side is bad (especially now with the plow hanging off the front) and it sounds terrible with the side tread I have. When I do it in a parking lot, people often look at my truck like something catastrophic is happening to the front.
If I put the plow on and hit a good bump with the wheels turned I get a slight rub.....but that's with a 850# plow and even then very minor.
Anybody want to buy a set of Welds??? LOL
I run 35's with a pretty good offset. I have a leveling kit and my bumper spaced out about an inch. They still rubbed pretty good on the fender plastic.
The second pic shows where I cut away some of the lower fender. On a unmodified truck , there are 2 bolts. I cut between the first and the second one.
The third pic is from the underside showing where I removed some of the fender metal, so I could zip tie the plastic further away from the tires.
I couldn't afford a lift and needed to make it work. I also had to take a baseball bat to the lower corners to roll them out of the way.
