1988 F350 460EFI. Been sitting for 20+ years. Need help to get it back to proper running condition
Yeah I was kind of worried about the tires. They don't look dry rotted but you never know. My dad also said that they might have flat spots from sitting in the same position for so long which probably wouldn't be good at speed. No matter what condition they are I can't really run those anyways because with the rims that are on the truck the tires are too wide and don't really turn at all. The tires rub very easily on the leaf springs when you turn. So I either need skinnier tires with same rims or the same tire with a new rim. I just wanted to get new rims and new tires and just avoid having any trouble with the old tires or the new rims still not having enough backspacing to handle the wide tires. Thanks for your opinion.
Ill add that the 16.5 rims will also limit you on the tire selection. Go up to a 17+ and you'll have much more to choose from. I've been on the old school 16.5 myself since 89 but the last tire change was very limited by that rim for 35" tires. Id go with your first choice and swap out for a whole new set of rims and tires.
These are the Ballistic Enigma that I was looking at.
Yeah not sure if I really want to run Humvee tires. I'm not too sure how they'd be on the road especially in snowy/icy conditions which I have a lot of where I live. And I'm not really sure if I want to stick with 16.5 wheels or not. But I never really thought about those tires before and they are an option so thanks for putting it out there.
Nice time capsule piece.
i would just change all the fluids and look everything over real good.
Tire would be the FIRST thing I would change, even if you had to put stock tires on. The rubber is hard as hell and once you warm them up, they will split and blow.
Is that some sort of visor on the roof?
i will go ahead and tell you..
dont be surprised when you break a valve spring or 2. or a lifter completely collapses..
full pressure on the valve train for years on end, with only occasional start ups is gonna trash the top end as soon as you wind up the rpms for the first time..
Also, while you're in there, grease any and all fittings you can find. Pull the drums off and make sure the wheel cylinders aren't frozen, make sure the calipers and slides move freely as well. When you run the engine, make sure it runs long enough to get up to operating temperature, and is allowed to run for some time at temp. This allows any condensation in the engine and exhaust to evaporate. Starting, running, and shutting off without getting to temperature is worse than just letting it sit. Good luck with the truck!
#28
#29
#30
