Help: Starter is tight but wiggles with spacers(starter can't connect)
Ok so the starter is two months old. Went out this morning and the starter turn the
Motor for 2 seconds and then loses connection and spins or disengages and spins if that's the correct wording. I got under there and the starter bolts are all tight but you can wiggle the starter up and done about a 1/8th of a inch and the spacer bracket is what its allowing to let its love because the spacer is wiggling with it. How is that spacer held on are there bolts that could be lose on that? What do you guys think?
Stewart
The starter gear teeth in the starter is 'thrown out' into the fly wheel when starting. For some reason the starter is spinning but the gear teeth on the starter are stuck and not being launched out. Take the starter back to where you got it and point this out. when they do a starter test it will be very evident as to what is wrong with the starter.
