Hey fellerrsss, I'm about to pull my hair out, I have a 1988 f350,with a 7.3, and now on these cold mornings my brake petal will throw itself to the floor when touched, it pulls back up and doesn't do it at every use, but is this vacuum related or from the master cylinder, would appreciate any intell, thanks
Well its kinda wiered, because the power steering acts funny too, if I'm sitting in like a drive through with the wheel half pinned or so, the steering wheel will almost like pulsate, kind of jerk back and forth
when you say it throws itself to the floor, are you saying it just about falls to the floor cause theres no pressure pushing back on it, or that it pulls itself away from your foot? does it stop at a normal height?
do you have the usual vacuum powered brake booster, or did someone convert to hydroboost? assuming you're on vacuum brakes, your steering pulse has nothing to do with your brakes
i used to have an f150 with a bad booster that would suck the pedal down whenever the engine was started, and couldn't be pulled back up with the engine running. the booster was obviously the problem there.
on some of these cold mornings, my van has had the brakes be very touchy or grabby, i'll barely touch the pedal and just about lock em up. tightening the rear brakes helped a bit.
They are regular power brakes, its when I start to push the pedal down it will go down more then normal, but it will just like jump off of my foot, have to pull it back up with my foot when driving, but now I just replaced my glow plug controller and its not activating, any idea on that, I accidentally bumped a wire together and it arched, could it have blown the fuse??!!!!
look at the first 3 please read first threds all in for in GP controlers is there ... when u arc the wrong thing yes you could have blown a fuse(fuesable link ) or u coulda have fried your solonoid ... as for the breaks im willing to bet its a M/C but i had a truck that the pedal whent to the floor and stayed there it got better the more i used the truck sat for 8 years but i only was fixed when i replaced M/C and booster only like 120 bucks for everything at my parts place and have not looked back lol
