Front passenger brake line
so if i got that right the flex line broak wher it connects into hard steel line thats bolte to the frame ?? if so your auto parts store will sell one ( id replace both driver and passanger) the flare not on the calaper is vary soft id only use flare nut wrench (box end wrench with section cut out to slip over line ) but its eazy .... id be much more whorried about bleeding your breaks after !! as its a complex job im not quafied you tell u how to do it im sure theres info out there for it !
Like Rocky said, it sounds like you broke the brake hose. I would also recommend you upgrade your hoses. LMC has a stainless set, bit pricey, but suspension upgrades never come without a cost. Truck Parts and Truck Accessories
I guess I'm confused as to how the flex part is typically held together to the steel line off the caliper? What holds them together? Where it seperated it looks like the steel line is barbed or something to hold the flex line on. When you buy this line new, does it come as one piece or is it flex line plus steel line?
Roger T. Pipe
08-01-2010 01:16 AM
power_speed
10-19-2007 07:47 PM
BioNate
06-24-2007 05:00 PM
