5.8 4x4 Gaser UP and RUNNING!
here's the thing... I have a battery isolator. Alternator burned out for some reason. Replaced engine computer and now it runs OK, alternator disconnected. It WAS smoking when i had it connected... Fuel-pump would run constantly and not that's fixed. So, WHAT is the minimum size of alternator I should put on to run that BOSS plow pictured, is there a MAX size amps that i would have to put on it? I have two battery's tied into a rectifier running one with the engine side and one that runs on the plow side to charge both battery's off the alternator.
I would check the harness thats the G2 alternator in that, they had harness problems with them catching fire. If it was mine, I would do a search find info on the G3 swap. Either grab one from a junkyard with a harness(taurus mid 90s box body had 130amp) or get a parts store one. Fuel pump constantly running check your relay had them stick before also. Company I use to work for that plowed in the winter all we ever did was tie the secondary battery into the primary(drivers side battery tray and cables connecting the 2).
Curtis
Curtis
Curtis
Curtis
looks like a 1g alternator... has the ring terminals that bolt on the back of the alternator.
ok guys!!! got the THREE G ALTERNATOR!! Off a 1995 mustang V6. Wiring seems easy. yellow to HOT side of starter solenoid NOT to the wire going to the starter. GREEN to GREEN wire coming from Voltage Regulator. WHITE loops to the SINGLE terminal S. Hope it gets working good! What size wire for the charge wire from the alternator battery post? what fuse should i put in line?
kramttocs
01-11-2019 04:39 PM
mcampbell545
10-15-2013 04:37 AM
