header gasket delete
many vehicles dont even use exhaust manifold gaskets, and you dont really need to if your heads are fresh and everything is square. if your having problems continuously the headers are probably warped.
Ive used RTV quite often. ive even taken two gaskets with 1/4 of rtv in between lol.
i stuck my headers in a vise, sprayed some chevy orange across the gasket surfaces, scraped over the wet paint with a square, ground down the high spots, clean off paint with acetone, 'rinse lather and repeat' like 20 times and perfectly machine shop straight! took a lot of patience using a tiger disc on a grinder and a dremel
there are a few companys that makes either copper or aluminum gaskets i have used both and they work great for these problems an old school mechanics trick also is to heat the headers up [1 pipe at a time,all bolts tight red hot] they will then bend and conform to the head if they are warped
yes x2 for sure i just couldnt remember the brand name but now i need to order some any ways i got into a project yesterday i real shouldnt have thought i would take a shot at changing the exaust gaskets on my s/c with a rebuilt 460 [po] i used an air chilsel to break all the d/s bolts free came out like butter p/s ended up breaking 4 bolts flush with the head upon getting the other 4 out i seen what some one had done there must of being 2 people working on that truck at i time the s.o.b used lock tight now i have to pull the engine to get the head off,drill out the bolts and finalt replace the gaskets
Header Hardware And Header Bolts
Should be able to find bolts as long as you need at the site below:
windevil pete
12-03-2007 08:58 AM
HogTied
07-03-2005 11:30 AM
ceetwarrior
20
12-21-2003 01:44 AM
