Just a few questions on 351w SD EFI rocker upgrade.
I've heard that the biggest thing I can do to my 351w SD EFI is to add 1.7 rockers. Now here is my set up 351w bored 40 over, slight cam for torque, 1978 HO heads, stock EFI truck intake, and stock manifolds.
Can I find the 1.7 rocker arms in the junkyard? Off of a roller 5.0 or possibly a 7.5? I plan to add long tube headers, but how much will the rockers help with the stock manifolds? Will the SD EFI need any tuning?
So far as exhaust I currently have true duals, 2 1/4" pipe, no cat, thrush welded mufflers. I need a new exhaust cuz mine is starting to leak alot, but I'm trying to wait until I get my longtubes.
Thanks guys for everything!!
on
Doesn't matter that engine got the same large chamber smog head as everything else from that era so CR is down around 8.3:1, and ports and valves are the same as later heads so they're nowhere close to appropriately sized for this displacement. The 351HO cam was pretty much a flat tappet version of the 5.0HO roller cam though so you're in good shape there, bolt on a set of GT40s and you get a bump in compression up to 8.8 to 9:1 and bigger valves and ports so you'll see healthy gains across the board.
Now, If I do a head swap will I have to build the bottom end again?
How much compression do you think I have with my engine being bored 40 over? I don't want to do a head swap and have to run mid or high grade fuel. and I also don't want to have to rebuild my bottom end. I only have 10,000 miles on this engine.
patrickj20
07-31-2017 09:07 PM
chrism0
01-14-2004 10:13 AM
