Hub Body Assembly 1996 F150 4x4 5.8 Dana 44
I'm rebuilding my front end. Needed brakes, rotors, ball joints, a few other seals and bearings while I have it apart. Thanks to this forum I have everything off the truck. But I want to dismantle the Hub Body Assembly.
Here are two pictures. First time I've tried to post pictures. So if they are not there I'll re-post. Or try the links below.
I want to dismantle this so I can clean/lube it. I've popped out the plastic tabs and it moved a bit, but now it's not coming apart. I don't want to force it, unless that's what I'm suppose to do. Can't find anything online. Maybe I need to press it out? Thanks ahead for any help. SWC
Ford Truck Enthusiasts Forums - Scottywc's Album: HUb Assembly 1996 F150 - Picture
hail destroyer
09-27-2016 10:03 AM
dirty1
29
08-05-2009 10:35 AM
Grey Fox
08-06-2004 02:15 PM
