Picked up a 96.. 5.8.. Time for dana 60s
picked up 96 with 5.8 and auto trans.. was a plow truck.. but i removed the harness and plow mounts.. gave it back to PO.. wasnt gonna spend 3k for a plow truck..
Suspension is too worn out.. and i was given a set of dana 60 1 tons.. because a guy nextdoor to me parted out a 2000 f250 diesel.. and was gonna scrap them.. blah blah blah... brought them over to my lot on a forklift..
-front needed brake rotors and pads.. needs an axle shaft on the passengers side..
rear needed brake calipers.. brackets... rotors.. and pads.. had to hunt down the proper grade 8 mounting hardware.. but i found it... and its an almost complete differential now.. needs a pinion nut.. lol
to finish the rear.. i need f250 driveshaft that i ordered.. and brake lines.... fill the diff with fluid and a nut..
i will post pics a little later
Man those axles would give give you another 600lbs of scrap weight! So now the plan should be to just stump jump it, toss axles in back, soak interior down with water, fill engine and fuel tank as well. That would be one hefty some bish. Prob get 600 outta it. I just kiddin. Good luck on your jouney of swappin in axles.
$36 is like 1 30 pack of budget beer, 10 cheeseburgers, and 6 fries at mcdonalds. You would be chowin like a king for a night. Your guts might hate you the next day, but hey, its beats being thirsty n hungry while you work on your bronco.
Iron here is 10 cents a pound. They pay $1 per rotor. Also scrap cars are 12 cents a lb. Sounds like scrap is cheaper where you are.
Is the bronco any good or is this gonna be a play toy.
The bolt pattern for the wheels are different so getting mud tires to fit isn't gonna be cheap.
I say go for it. Buy some 1ton van coils and retro fit some long arms onto the strait axle and some coil perches. Sounds like a fun project.
