f100 wont go into gear
Old 01-14-2013, 01:09 PM
realmccoy1978's Avatar
realmccoy1978
realmccoy1978 is offline
Alright so I just bought a 1978 f100 with a 302, 4 speed manual trans. I jumped in and took off to drive it home, geared up through to 3rd gear. I tried to gear back down again, but it just went into neutral and wouldn't go into any gear at all unless I grabbed the shifter and literally slam it down into gear.. now it doesn't even want to shift up smoothly like before. I have a feeling the clutch needs to be adjusted, but I'm unsure how to do it on a mechanical clutch like this truck.
What gives??
Old 01-14-2013, 07:08 PM
79_FORD_F-100's Avatar
79_FORD_F-100
79_FORD_F-100 is offline
On my 300/w g-low 4sp there is a rod near the driver side of the bell housing that pushes the clutch fork towards the rear of the truck. The other end of the rod is threaded for adjusting. If yours is the same adjust the bust toward the front of the truck. Hope this helps.
Old 01-14-2013, 08:08 PM
realmccoy1978
Right on, ill give it a shot. How do I know how far to adjust it?
Old 01-15-2013, 08:03 AM
realmccoy1978
Bump.......
Old 01-15-2013, 09:02 AM
79_FORD_F-100
Tryall and error
DRKELLY
08-01-2022 12:48 PM
Oliver Herting
08-08-2017 04:22 AM
BillyPhilly
10-14-2013 05:07 PM
Rock_N_Roller
07-31-2001 01:24 AM
77_F150_4x4
09-25-2000 03:47 PM
Quick Reply: f100 wont go into gear
