99 F350 boost air leak?
on
I have a 99 early series with 170,000miles on the motor. Recently I notice the truck seems lazy when pulling away and the boost reads 0 psi and there is an air leak noise from under the hood. Once it shows boost the leak noise stops until the truck evens out and starts to cruise, boost returns to zero and the noise comes back, As soon as you increase power the leak goes away, as long as there's load on the motor there's no noise but as soon as it's levels out here comes the noise. I have a biig boost valve onit and thought that was my issue but I removed it and went back to stock andit's still doing the same thing. My fuel mileage seems to have taken a crap too since this started, down to about 10MPG from 16.
Any guru's out there?
Regardless of having new boots you should do a boost leak check. There can be leaks that are not do to boot problems.
makomaker
06-01-2008 03:55 AM
