Where does this wire go ????
Old 01-22-2013, 09:24 AM
K9sicem's Avatar
K9sicem
K9sicem is offline
I know it's not Ford but it's the only Alt I had laying around. I'm too cheap to go get a new one. I think the white wire goes to the switch, But I'm not sure which post on the switch. I ran the red wire to the Alt post and added the black wire from the amp gauge. The other side of the amp gauge goes to the battery. And the green wire was grounded. I do not want to hook up the battery until I know the wires are in the right place.
Which post will the white wire attach too?
I have the engine running now. If you want to see/hear it run here is my YouTube link.
Old 01-22-2013, 08:49 PM
economan's Avatar
economan
economan is offline
white wire goes thru the "GEN" light then over to the key switch on the run position, just check it with a test light to get the right terminal, it's the term that runs the gauges, coil etc. but doesn't light up in the "acc" position
for a simple wiring diagram of the alt itself just do a quick google for "delcotron wiring diagram."
mikie
near ottawa canada
58 merc 100 panel, 64 econoline p/u
stufarmer
1999 to 2016 Super Duty
01-17-2017 01:35 PM
69 SHORTY
02-21-2016 08:11 AM
BigB9000
12-27-2012 02:54 PM
alpha/omega
Offroad & 4x4
06-06-2011 08:35 AM
g84t8f1
Electrical Systems/Wiring
01-22-2009 06:29 PM
Quick Reply: Where does this wire go ????
