Torquing upper shock mounting nut
I replaced the front shock absorbers on my Ranger today and I have a question about torquing the upper mounting nut. The problem I have is that the threaded rod that is attached to the top of the shock turns when I put a socket on there and try to torque it to the proper spec. You can put a crescent wrench on the top of that threaded rod(it has flat spots) and tighten the nut some with a wrench, but the crescent wrench wants to slip and round off the top of that threaded rod. So my question is, how do you torque that upper nut without the shock spinning below?
I'm sure I'm missing an easy solution!
It's a '98 2.5 ltr., 2 wheel drive with coil springs.
Snap-on Tools
http://www.napaonline.com/Catalog/Ca...240_0006394289
there is a specific tool to loosen/tighten. i would also ck napa or other car parts stores
Snap-on Tools
NAPA AUTO PARTS
NAPA AUTO PARTS
You know how frustrating that gets.
I think I will look in to getting one of these, but the 18.00 price tag is kind of heavy.
Thanks for the link.
FWIW, I've used (on occasion) a pair of vise grips to hold the shaft and allow me to tighten or loosen the upper mount.
The shaft is hardened and the vise grips are not, so the shaft is not damaged in any way. If you use this method, you should grip the shaft through the coils as high on the shaft as you can, just as a precaution. The seal on the shock won't ever reach this high.
I did pick up one of those shock absorber sockets and got the nut tightened properly. They come in different sizes, so make sure you get the right one. The one I got was a tad bit big, but it still worked...barely. It was only about $2.50. Thanks for the help!
02GrayPowerStroke
04-22-2009 06:36 PM
atrmg1610
1999 to 2016 Super Duty
16
11-11-2008 08:17 PM
BrianA
03-22-2004 02:22 AM
