09 F250 Rear Diff Fuid Change
I just picked up an 09 F250 a couple of weeks ago and I was planning on replacing all the fluids since I'm not sure when everything had been done in the past, but it did pull a camper 5th wheel. It has about 93000 Km/57000mi on it
One thing I noticed when reading the manual is that a rear diff fluid change is not necessary on these rear axles unless they have been submerged in water or repaired etc..
Just after I got it I noticed the pinion seal was leaking. It was fixed under warranty but the dealer did not replace the diff fluid as they said Ford will not pay for it.
My question is do you think I need to replace the diff fluid or should it still be good, given the relatively low mileage.
Thanks in advance,
Thanks in advance,
on
Ya as much as I's like to leave it, common sense leads me to change it since I bought it used and really don't know how much it pulled in the past and what kind of wear it has. I'm going to go ahead and change it.
So the consensus is to use Mobil 1 synthetic 75/140 with lubricity additive?
I did an oil change and used Mobil-1 75-140 synthetic that had the LS additive in it. The truck has a very minor chatter when turning sharp in cold weather. Otherwise, the limited slip rear end seems to work well.
If totally smooth operation is desired, I think that some of Ford's limited slip additive should be added to any rear end oil that already has some LS additive in it.
Next oil change will get a bit of Ford's LS additive.
Lou Braun
Lou Braun
on
Lou Braun
Lou Braun
When I changed out the ring & pinion from the 3.73 LS to to a 4.30 LS I had the dealer replace the limited slip clutch's since only the right rear spun on grass and our truck was still covered by the factory warranty.
When I put it back together I filled the differential with Mobil 1 75-140 which contained the friction modifier along with just 2 oz. of Ford friction modifier.
I'm now going to install the Ford aluminum rear end cover and since we've run the new ring & pinion a season I'll probably go with new fluid (with the friction modifier) even though it's costly. I just think since we are towing relatively heavy most of the time maybe it's a good idea to change it out again since I probably won't change it again for the factory suggested mileage interval from here on.
In you guys' opinion should I add the Ford friction modifier even though the Mobil 1 contains it or just go with what the new fluid has in it?
