Transmission lines part # or Help?
I need help? I currently have an 2002 F-250 V-10 with a transmission cooler. The lines began to leak running from the bottom of the radiator to the cooler. I was able to cut out the metal and mend with hose and clamps. It worked fine. But in the process of fixing it I must of bumped the other line and it began to leak close to the fitting going into radiator. I couldn't cut the line and repair with hose because it was to close to fitting. I removed the fitting from the radiator but the line broke where it was leaking from. Does anyone out there know how to fix the line or what the replacement part is I should be looking for. All the local big box store say to replace with hose. But that doesn't do me any good with fitting that is broke off at the line. I need a new fitting and line? One side is threaded going into radiator and the other is barbed which goes into a rubber hose that goes up to trans. cooler. The line I am interested in on the driver side of the radiator and feeds in close to the bottom of it
Thanks in advance if you reply!
http://www.autopartswarehouse.com/search/?Ntt=Transmission Oil Line
Try here
You can change specs as needed and there is a chat person- who knows if they know anything though LOL
http://www.autopartswarehouse.com/sk.../RB624253.html
Try here
Brokewhiteguy
09-09-2014 06:01 AM
WachusettF150
06-14-2010 05:34 PM
