1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2006 5.4, misfire on #7 At idle...but
Old 01-15-2013, 09:12 AM
markshells1960's Avatar
markshells1960
markshells1960 is offline
Unhappy 2006 5.4, misfire on #7 At idle...but
Swapped, coil, plug, injector, ran compression check, cant find a vacuum leak, valve train ok swapped pcm, checked all wiring, plug is dry when pulled, but miss continues at idle and just off idle. scanner (snap-on Solus) shows 23% loss in #7 when returning to idle. and fuel trims on theat bank are about 18%+ but return to normal at 2400 rpm...vacuum leak right? cant find one no matter what I try. Any ideas?
Old 01-15-2013, 10:07 PM
jh818's Avatar
jh818
jh818 is offline
How about the rubber boot? Any cracks? Spring in the boot connected good to the plug?
Old 01-16-2013, 06:59 AM
markshells1960
Three times over by two people
Yeah, we did that check over and over, three different coils just to be sure, the work fine in other cylinders just #7 giving us trouble.
arco777
Modular V8 (4.6L, 5.4L)
13
04-22-2011 08:21 PM
cougarmandan
08-06-2010 08:45 AM
Jeff Dodson
1997-2006 Expedition & Navigator
01-04-2010 09:52 AM
fomoco32
Modular V10 (6.8l)
02-19-2009 04:08 PM
Quick Reply: 2006 5.4, misfire on #7 At idle...but
