Need Help ASAP! Titan Tank install gone Wrong
Old 01-08-2013, 09:50 AM
Doonz's Avatar
Doonz
Doonz is offline
Hey Guys.
Installed a 65 Gal Titan Tank the other day. I Finally got a chance to fill her up all the way.. well as much as i could.
My Level sensor is not functioning and I was only able to put in a total of 160 Liters when it should have been right around 246L.
My question is this.
I need to syphon my tank now. Is there anything preventing me from doing that or will a 1/2 hose work??
Thanx. Please just answer the question as im out in the city and need to purchase the hose and a 55gal drum.
Old 01-08-2013, 10:00 AM
SavageNFS's Avatar
SavageNFS
SavageNFS is offline
Received 6,931 Likes on 2,179 Posts
I don't see why syphoning wouldn't work...
Old 01-08-2013, 11:08 AM
rob92761's Avatar
rob92761
rob92761 is offline
is it reading at all? and what is that reading?
you can check to see if the sending unit is plug in. you can see it between the truck bed and the frame rail.
Also i had transfer flow tank that the sending unit float got hung up on the bottom of tank. took it for a drive fix that.
Old 01-08-2013, 11:40 AM
Doonz's Avatar
Doonz
Doonz is offline
Yeah, i double checked the electrical connection. It still wont read anything. Even tho i did put 160L in the tank. I couldnt put more in. So now im driving around trying to find a cheap transfer pump and a 205l drum with no succeas. Pisses right off. I mean its 4 hoses one electrical plug and 8bolts. Not sure how it so buggered up
Old 01-08-2013, 12:26 PM
darren32's Avatar
darren32
darren32 is offline
Specialy Sleds should have some empty VP barrells for ya
12518-128 Street
Edmonton, Alberta
Canada
T5L 1C8
780-451-1130
Sorry buddy, I just chucked 2 45 gal VP barrells
Old 01-09-2013, 08:01 PM
Doonz's Avatar
Doonz
Doonz is offline
Hey Guys,
THanx for the replies.
Siphoning is pretty much impossible . Has to do with the turn into the tank on the filler hose. Anyhow the problem was the float was touching the side of the tank.
The instructions were very misleading. instead of keying it the way the oem tank was just follow the picture for the fuel sender unit and you will be good.
As for only 160L going into the tank. LMFAO apparently the gas station's machine needs a recal. We pulled 230 some liters out of the tank with 28L being used on the trip computer.
All is good now
Old 01-09-2013, 08:06 PM
darren32's Avatar
darren32
darren32 is offline
Good news
Old 01-09-2013, 08:09 PM
SavageNFS's Avatar
SavageNFS
Glad things are working correctly now.
Old 01-09-2013, 08:42 PM
displacement4me's Avatar
displacement4me
displacement4me is offline
Good to hear it was a simple fix. Did you pick your tank up in Alberta ??
Old 01-09-2013, 08:46 PM
Doonz's Avatar
Doonz
Doonz is offline
I ordered it through a truck part shop in edmonton. Talked with the guys from Titan Tank and they said to do it that way versus getting them to ship it to me
Old 01-09-2013, 08:59 PM
darren32's Avatar
darren32
darren32 is offline
Call NADP for a price. Their prices on the titan tanks are pretty good
Old 01-09-2013, 09:21 PM
Y2KPSD's Avatar
Y2KPSD
Y2KPSD is offline
Picked up at plant
I picked up mine at their site, and they had it installed next door at the Chebby dealer.
Very fast and professional. Installer didn't like some of the looks of the bolts. Factory guy brought more over in 3 minutes. Installer said he's done over seveal 1000's units.
Good job
Old 01-09-2013, 10:23 PM
RM2738's Avatar
RM2738
RM2738 is offline
Originally Posted by Doonz
Hey Guys,
All is good now
Sounds like you got a little bit of free diesel.
Old 01-09-2013, 11:51 PM
P.Bronner's Avatar
P.Bronner
P.Bronner is offline
-- Yeah, now just don't tell the station owner, and keep going to that pump.
zephyr78
07-16-2012 08:55 PM
jgilrfr
06-20-2011 12:28 AM
Superred2
29
12-04-2010 04:25 PM
gray91
19
08-04-2007 07:06 PM
Dean
07-08-1999 06:12 AM
Quick Reply: Need Help ASAP! Titan Tank install gone Wrong
