87 f250 HELP (for an old lady that needs her truck)
You should only have power at white in the "Start" key position.
Duraspark II
With the coil connected (backprobing the Horseshoe connector) you should only 'see' about 7.5V going to the coil in "Run".
This question would likely be better answered in the '80-'86 forum as the only '87 vehicles still using DSII were carburator 460 & 351HO trucks with GVW over 8500#
DSII was completely gone by the '88 model year except in certain RV's and chassis only models
Duraspark II
As you can see, the DSII system works by breaking the coil ground (green 'Tach' wire) when the distributor pickup pulses.
Power to the white wire in "Start" signals the DSII module to retard the spark timing 3* in order to ease load on the starter.
While cranking the coil gets full battery voltage. In "Run" voltage is reduced to keep from burning up the coil.
Perhaps the switch itself -or the plug- has overheated and has now has a short or crossed wires.
You shouldn't have power to both the red & white wires of the DSII module at the same time.
You should have 12V in start and ~7.5V in run at the coil *with some load applied*.
If you are measuring with a DVM and the coil disconnected you will still "see" 12V because there is essentially no current flowing.
It also sounds like you should either charge your battery or check the system grounds.
An automobile battery should be around 12.5V at rest.
Hope this helps.
Well there is a ballast resistor, which I totally doubted earlier. My Haynes manual shows basically the same diagram that Ard posted only not as colorful. I don't know why I didn't think to look at the Haynes manual earlier. I'll try to post how to check the ballast resistor:
1. separate and inspect the ignition module two-wire connector with the red and white wires.
2. Unplug and inspect the ignition coil connector.
3. Attach the leads of an ohmmeter to the BATT terminal of the ignition coil and the red wire in the module connector.
4. If the indicated resistance is the same as specified, the resistor is okay. Indicated is 0.8 to 1.6 ohms.
5. If the indicated resistance is less or more than the specified primary resistance, replace the ballast resistor and recheck ignition coil supply voltage.
6. Reconnect the module plug.
I removed the wire's from the coil when I tested it didn't know it had to be on the coil I will test it again ....
I tested the coil wire's again same with the wires on the coil or off..
I had the igniter module (DSII ?) module tested at AutoZone they say that is fine ...
So I got a hair up my butt and put power to the wire I removed from the starter solenoid and left the key in the run pos and the truck started(used a starter switch) ? I thought the only thing that wire was for was to engage the starter?
Why does the ignition switch not engage the starter?
Why seeing battery voltage in both run and start at the ignition coil?
The only effect of an open resistor wire would be no coil power in run.
The ignition switch plug (pigtail) go bad often enough that they are widely available in the aftermarket.
