Fuel Tank Sending Unit Outlet Pipe Diameter?
I have an 85 F150 with a 300 cu. in. 6 cyl. engine.
I am planning on changing my leaking fuel line which is currently a combination of a steel line at the front and a plastic line at the back to the tank. I would like to replace it all with a steel line running from the pump to the fuel tank sending unit with a short piece of rubber fuel line at the pump and at the fuel tank sending unit.
My question is what is the diameter of the fuel tank sending unit outlet pipe?
Thank You
Thank You
wdhille
18
06-22-2010 03:06 PM
driller tom
01-09-2010 08:30 PM
