7.3 Diablo sport preditor programmer
Category: Engine - Power Adders
Price: $250
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): NSX
Item Condition: CA
Engine: Part suitable for diesel truck
99 to 03 7.3 luny2nz@yahoo.com
I cut and pasted the below info:
What are the advantages of the Predator Tuner?
The Predator Tuner was created with one goal in mind, POWER! 10-30% increase in horsepower and torque, depending on application. The Predator Tuner's additional power makes itself noticeable immediately with increases in power that start in the low RPMs and build into a frenzy at the high RPMs. Once the vehicle is reprogrammed, the Predator Tuner is removed from the data port. There are no tools required for installation. There is nothing connected to the vehicle that might come loose or fail.
A reprogrammed vehicle will notice significant improvements in drivability. The additional power and improved shift patterns created, will yield quicker acceleration, firmer shifting, better mileage, and improved towing characteristics. Whether in local traffic, out on the highway, the power increase in lower RPMs will yield better throttle response and help maintain speeds on inclines. The wider power band that the Predator Tuner creates will be noticeable in city driving, where speeds constantly change. The mid to upper power increase is extremely useful, on the highway, when passing slower vehicles.
Increased Fuel Mileage
The increase in MPG is a byproduct of maximized engine efficiency. The improved timing curve and air/fuel ratio creates a more complete combustion, i.e.: the engine extracts more power from each molecule of fuel. Fuel mileage increases of 1-4 mpg are typical.
Will not crash vehicle's computer, has a safety backup.
Upgradeable through the internet, there is need to send the programmer back
Includes full diagnostics software. Not just a code retriever. The predator will allow you to read diagnostic trouble codes (DTC), erase DTCs and perform live data monitoring. You can monitor your engine sensors while driving your vehicle.
Improve shifting: add firmness and precise shift points
Adjusts speed limiters / Raise top speed limiter
Program installs in less than 5 minutes. No long waiting
Improves timing and fuel curves
Reprogram your processor for optimum performance and drivability using download and flash technology
Allows fine tuning adjustments to timing and fuel curves of DiabloSport tune
changes
Adjust shift points in vehicles with automatic transmissions, and increase line pressure for quicker, firmer, more precise gear changes
Ability to re-tune vehicles after factory re-flash of PCM
Predator flash tool allows custom tuned downloads
Multi-vehicle diagnostic tool with live data monitoring and fault code scan/erase capabilities
Power Profiles
40 hp 110 ft/lbs torque
60 hp 145 ft/lbs torque
85 hp 190 ft/lbs torque
100 hp 200 ft/lbs torque
carbonmetallic
12-11-2008 06:01 PM
FTE Ken
1997 - 2003 F150
151
12-27-2005 12:15 PM
FTE Ken
1997 - 2003 F150
30
03-10-2005 09:37 PM
FTE Ken
1997-2006 Expedition & Navigator
22
09-27-2004 08:37 PM
