7.3 vs 6.4 for Alaska cold weather operation and extended idling
Moving to Alaska in May this year and will be buying a Superduty. Which engine will be better suited to cold weather operation and extended idling, the 7.3 or the 6.4?
6.4s can have issues with fuel diluting the engine oil because of the DPF regen cycle. None of the DPF generation trucks are particularly well suited to idling. Light duty cycles and low load states tend to fill the DPF quicker than when the truck is being worked hard.
